For the bonnet I used a craft knife, for the wings (fenders) a mixture of a razor saw & a Dremel |
You are definitively CRAZY! I'm sure that the result will be a kill |
glue- i use e.m.a plastic weld cement it works great. what do you use???
the plastic you using i could do with fixing some of my body`s with it the source of finding the thin stuff where can you buy from???? jason |
Glue is just regular plastic kit "poly" stuff; styrene sheet came from eBay e.g. item # 171068324906
The following user(s) Liked this: kemmatech
Jon your a brave man cutting up that scorcher shell i would be very nervous doing it
but have to say it looks pretty dang good so far a very brave project but i think you can pull it off. Ill be following this one closely |
Last edit: by Jonny Retro. Reason: badword filter
Cutting it up is easy - it's looking at the rather minimal shell left at the end & wondering where to start putting it back together that was a bit scary |
Boot floor fitted, not exactly as the 1:1 car but it'll be hidden anyway ... front end is now nice & stiff & not parallelogramming at all...
Sun visor cut out, bent & fitted: Rear firewall was a little problematic - I really needed one of those pin block doodads you use to reproduce the shape of door architrave when you cut a carpet to fit a doorway (the correct name of which escapes me at the moment ... but I got there in the end Rear firewall needs to be 3 dimensional, so had to be glued in stages ... Fitting "ears" on the back end.... ... no idea what is supposed to be between them, I guessed a wing |
Another masterclass how do you progress so quickly
