"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25218
:) I tested a easy and removable dirt, it is to use wood white glue mixed with water 50/50 and put some very fine sand on before drying. I do that for my diorama's ground
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25219
Peelable dirt? Excellent :y:
I might give that a go - but I think the paint will need a while to harden off first :)
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25220
:) You just have to brush the withe glue on your body where you want, and put a very fine sand or dry scrub. :y: I made it on my first grasshopper 2 and when it didn't pease me just a warm shower and it is gone. :y:
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25261
WOW excellent, i love how this Baja Bug looks like !
I ont think that the Topic name is still accurate...It doesn't look "Budget" to me, i would rather change the name into "excellent Bug" :y: :y:
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25262
I had a go at making a shorter body post - I thought the machined out end would be the tricky bit, so started there ... this was the second attempt, I broke a titanium nitride drill off in the first one, that wasn't go to come out in a hurry :whistle:
M3 tapped to fix on to the the shorty body post still on the car:
Marking & turning down the pointy end:
& the other end ... untouched bit between the two needs to be tapered ...
I probably should have left it here & lived with the step near the top, but I pushed it a bit to far ... I wouldn't say I spoiled it, but it could have been better :(
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25264
....It doesn't look "Budget" to me...
It's a reflection of what it says on the roof, rather than the costs :)
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25320
Netting sold as Super Champ / Hot Shot ..., umm, netting arrived... gaps are far too big & they're not even square :( :n:
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25324
:woohoo: LA CLASSE :y:
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25334
Regardless I think this netting suits the scale and looks perfect B)
"Budget Bug" decals for Sand Scorcher, etc 13 years 1 month ago #25344
You can build yourself the net, I think.
Take a wood plate, use it as a frame and make a square with hammer and nails all around.
Then use some cotton wire and build the net. You can choose the shape and the dimension of the net squares.
Then use some vynil glue on the cotton wires and let dry*.
Once dry you paint it as you like and trim away the extra net not needed.
* Keep in mind that the net must be raised and separated from the wood plate or they will be glued all together.
Max
Time to create page: 0.197 seconds
