Re: Tamiya Ford F350 Highlift 3 SPD "Make over" 14 years 11 months ago #4394
Re: Tamiya Ford F350 Highlift 3 SPD "Make over" 14 years 10 months ago #5319
This is so cool, hope to see pictures of the front hood finished, i have never seen this on a custom high-lift before. The color, blue for the engine and red for the diff caps is a good one too, it is used quite a lot for restaurations of 40s/50s REAL trucks. 1954chevypickup...rom-2.html
Feraz
Last edit: by achmedachmed.
Re: Tamiya Ford F350 Highlift 3 SPD "Make over" 14 years 10 months ago #5329
Hey thanks Feraz, I must actually update this thread. The F350 is basically done apart from some small teething problems.
I'll update it later today.
Re: Tamiya Ford F350 Highlift 3 SPD "Make over" 14 years 10 months ago #5339
That rear cage is a piece of art, looks like you did some copperweld :woohoo: Nice bended curves.
Did you cut the fronthood with sewingtread? beacause it seems you didnt lose much plastic material when removing the fronthood.
Feraz:)
Re: Tamiya Ford F350 Highlift 3 SPD "Make over" 14 years 10 months ago #5345
I tried the sewing thread method, but I couldn't get it to work properly. I used a Dremel. The best tools for any RC builder. I used the thinnest cutoff disc. About 1mm.
Here is some more of the build process. I copied the most common mods on the internet as you can see. This mod drops the centre of gravity, which is a big problem on the Highlifts.
As you can see, I did away with the leaf springs, they are more pain than pleasure. If you roll over, they bend. I'm using them in a trailer I'm building for the F350. 21.5 turn brushless provides the power for the truck. Finished off with custom 4 links suspension.
And I inverted a 17kg metal gear servo and installed it in front to add more nose wieght.
I'll find more pics and update soon.
Last edit: by Louisbaby.
Re: Tamiya Ford F350 Highlift 3 SPD "Make over" 14 years 10 months ago #5356
I recently bought a razor saw (with a 0.3mm blade) & have found it very useful for longer/straighter cuts :)
Re: Tamiya Ford F350 Highlift 3 SPD "Make over" 14 years 9 months ago #5545
Couple pics of primer:
Couple of coats of "XF-51 Khaki Drab"
More soon...
Re: Tamiya Ford F350 Highlift 3 SPD "Make over" 14 years 9 months ago #5546
Don't worry too much about the marks on the bonnet in the first picture, it showed up after spraying the primer so I sanded down and refilled the area before spraying the main color. The other picture has probably got you guys wondering what it is I sprayed there. Here it is installed:
It looks much better when the body is installed, and you open the bonnet. I will neaten up the wiring when everything comes together.
Here is the finished Grill/bumper:
I've got a surprise with the paint work. Something totally different to the normal themes on F350s. I should have progress tonight.
Re: Tamiya Ford F350 Highlift 3 SPD "Make over" 14 years 9 months ago #5579
Nice, doe you plan to make something to lock the fronthood?
Like a pressure and klick system or something? :cheer:
Feraz
Re: Tamiya Ford F350 Highlift 3 SPD "Make over" 14 years 9 months ago #5591
Hey Feraz, i'm using a magnet system I used before on scale hatches on my dads airplane. It worked great. I'll post pics soon.
But for now, my progress:
Looks a little different to the other Tamiya F350's out there...
Time to create page: 0.165 seconds
