My M chassis builds 5 years 10 months ago #62988
Day 7 ...
My M chassis builds 5 years 10 months ago #62989
I didn't want to buy another driver sprue just for the headlights, but I do have quite a few spare Wild Willy headlamp outers.
I started by adding a load of Milliput to the backs of 4 of them:
Setup 1 - centre drilling outside end:
Setup 2 - pass(es) to even up the sides, supporting with live centre:
Setup 3 - facing "back"
Setup 4 - first angle ...
Setup 5 - 2nd angle ...
Edges sanded a bit, finished apart from tapping fitting holes ...
The following user(s) Liked this: caprinut, stingray-63, 1972 LeMansGT Jim
My M chassis builds 5 years 10 months ago #62990
Decided I wanted illuminated lamps instead, with a much older look to them, this is progress so far:
The following user(s) Liked this: caprinut, AndyAus
My M chassis builds 5 years 10 months ago #62992
  • Al
  • Al's Avatar
  • Hog Heaven
  • Hog Heaven
Jonny those lamps look brilliant . How did you manage to cut the rings of plastic ?
Thanks.
My M chassis builds 5 years 10 months ago #62994
Thanks.
Mark centres 20mm apart on styrene sheet, step drill holes out to 12mm, use template to mark 17mm outer circle, cut/Dremel/sand round :)
The following user(s) Liked this: caprinut, Al
My M chassis builds 5 years 10 months ago #62996
  • Al
  • Al's Avatar
  • Hog Heaven
  • Hog Heaven
Thanks Jonny.
My M chassis builds 5 years 10 months ago #63003
Day 8, mostly motor (2 steps in the manual).
The fog lifted for the first time in 3 -4 days, 3.6C (but warmer in the sun) & 91% humidity wasn't ideal, but I wanted to get the blue backing on...
My M chassis builds 5 years 10 months ago #63004
Front fenders, more work on the lights ....
The following user(s) Liked this: caprinut, Edou, stingray-63, Al, 1972 LeMansGT Jim
My M chassis builds 5 years 10 months ago #63005
  • Al
  • Al's Avatar
  • Hog Heaven
  • Hog Heaven
I respect your restraint Jonny.
The following user(s) Liked this: Frogfish42
My M chassis builds 5 years 10 months ago #63010
Nice as always!
Will those lights be painted brass color as early cars had brass lights?
Time to create page: 0.163 seconds
