Ford Ranger XLT Custom + Rob Mitchel's Champ 12 years 3 weeks ago #31518
Polished up the roll cage and fs plate then finished cleaning the bumper, fitted them altogether using some clamps instead of just cable ties :) I notice that when the cage hoop is fitted I can't have the top bolt in the motor cover? Am I suppose to trim the cover or not have the bolt? the cover does fit snug against the hoop :blink:
The following user(s) Liked this: Manotas
Ford Ranger XLT Custom + Rob Mitchel's Champ 12 years 3 weeks ago #31519
Nice and shiny looking car you got there !
Excellent work Andy :y: :y:
Ford Ranger XLT Custom + Rob Mitchel's Champ 12 years 3 weeks ago #31520
... Am I suppose to trim the cover or not have the bolt? ...
You're _supposed_ to use the cable ties, that way the offset :whistle: between the end of the bar and the roll bar doesn't matter ...
I guess whoever measured up for the offending part was one mistake away from getting fired & rather than own up, they called dropping the clamps "cost reduction" and "weight saving" instead :blush:
Ford Ranger XLT Custom + Rob Mitchel's Champ 12 years 3 weeks ago #31521
That will be why the hoop on the rere Fighting Buggy is a different shape.
Ford Ranger XLT Custom + Rob Mitchel's Champ 12 years 3 weeks ago #31523
Could you seek a mm or so by machining bolt/nut down, it would still 'look right' but clear case.
Ford Ranger XLT Custom + Rob Mitchel's Champ 12 years 3 weeks ago #31526
Nah it wouldn't be enough :dry: The only way would be to trim the plastic case :S and I wont be doing that ;) To be honest the hoop is fitting very snug against the case that I'll just leave well enough alone :)
Ford Ranger XLT Custom + Rob Mitchel's Champ 12 years 3 weeks ago #31527
You could make a replacement rear bar (it's "just" 4 bends & 3 holes) with a bit more space between the first two bends :)
Ford Ranger XLT Custom + Rob Mitchel's Champ 12 years 3 weeks ago #31529
Absolutely :) I expect it would be a heck of a easier than the XLT roll bar :laugh:
Ford Ranger XLT Custom + Rob Mitchel's Champ 12 years 3 weeks ago #31530
Finished assembly of the steering after polishing up the servo mounts and cleaning all the rod components B) I changed out the steering arms with the pressed ball link for another set with threads :) Next I need to clean up the msc and fit the rest of the radio before continuing with the bodywork, but the body can wait till I've spent a little time on the XLT :)
Ford Ranger XLT Custom + Rob Mitchel's Champ 11 years 11 months ago #31944
Made a copy of the chassis to create a top deck for the XLT, shaped and cleaned to test fit :) I'm not sure yet if I'll keep it covering the servo (everything clears) but I do like how fitting over the front mount gives plenty of chassis stiffening :y: added an ESC and that's it for tonight :)
Time to create page: 0.244 seconds
