confused.com? lower shock mounts?? i just want to upgrade the standard shocks i have fitted without spending out too much money. the wife is starting to get twitchy lol
is this the lower shock mounts mod you are talking about? www.ebay.co.uk/...084wt_1054 |
Last edit: by agemax. Reason: link added
I was talking about the regular parts from the Hornet to be able to fit the shocks from it also.
These are the D parts and the (lower) damper mounts... But then you'd also receive some parts you don't really need. What you've linked to looks like a cheaper (probably also easier) solution. With these parts you can fit some generic shocks. These should be about 80-85mm - I've measured. Combined with the modified Hornet parts (in your ad) this would be an alternative. |
That would technically be the correct thing to do I guess.
But I'm not sure if it'll make a lot of difference... You could also increase the tension on the springs by placing a (small) tie wrap at the end - around the damper housing. Effectively making them a bit shorter and stiffer. |
or maybe i could make up some spacers, various sizes to see which works best |
