oops, sorry boss, i already started a new one,delete it and change the name of this thread if you think that is best |
Will do. I was just thinking this has become a very informative thread that deserved to get a redefined title.
You can tell me what you want it to be - that's your prerogative of course. Keep them updates coming please! And I wouldn't want to waste the work you put in this summary :
Yes, those are the arms I have on my Hopper also.
I put on the CVAs from the Super Hornet too but these turned out to be a bit too long. I'll measure and look around. Advantage of these arms is that they are a little wider and they allow for the bottom of a normal shock to bolt on. A very effective upgrade for the original topic title - the straight line stability. This is what the CRP set up looks like btw : |
that crp set up looks way cool. is that a different chassis or are the top shock mounts a crp add on? |
got the new modified rear bottom shock mounts today, they fit well and look cool. new axle all built with new shafts, gears and bearings.
the new mounts come with pilot holes for the shock ball joints to screw into. do cva shocks use the same size ball joints as the standard steering ball joints or are they different, if so where can i get them? |
They are part of the CRP kit. The normal shock towers need to be taken off the chassis and the body modified to fit it... Concerning your CVA question - not sure which ball connector fits exactly (I've been using king pin type connections myself) but a set of CVAs comes with a pair of them at least. For "basic" fitting, Tamiya ball connectors are usually either 4mm or 5mm. Grasshopper steering uses 4mm connectors. I think here they might be using the 5mm variant. |
Results of a bit of research...
The Super Hornet uses 64mm CVAs on the front - a set of 50519 should do the trick. Possibilities for these are 55mm and 64mm but I don't think these lengths are absolute and can be played with a bit. I got the longer setting (without spare parts) to work on my G-Hopper. When using the Super Hornet arms, you will also need some 3mm screws of different lengths. Don't think you'd have to get the original screw bags. Probably a local hardware store will have them. I can be more exact if you want but they should about 20-22mm length. Thinking you also won't have a problem getting or creating the appropriate bushings that might be needed. |
