Vintage Manta Ray customisation quest 13 years 5 months ago #21812
Use a spatula ;)
Vintage Manta Ray customisation quest 13 years 5 months ago #21870
  • Edou
  • Edou's Avatar Topic Author
  • Hopping Mad
  • Hopping Mad
:P
Body supports made height adjustable and an FRP chassis undercowl fitted :
Velcro on the rear so I can reach the battery compartment...
Vintage Manta Ray customisation quest 13 years 5 months ago #21889
Why you're using the undercowl at the tube?
I've asked it before: Is it possible to use a 65mm damper at the front of a "top force"? Or is it to hard for a df01 buggy? for eg db01 is drivin' with 65mm front dampers and the df03 has short dampers too.
Last edit: by funkindemup.
Vintage Manta Ray customisation quest 13 years 5 months ago #21890
  • Edou
  • Hopping Mad
  • Hopping Mad
I think 65mm will be too short for a buggy damper stay...
Not sure how far you can stretch it but I think anything below 80mm is going to be troublesome.
The other cars you mentioned both have much lower shock towers (more like TA on road).
:dry:
If you drill additional holes, it could work of course. But might not look right...
Vintage Manta Ray customisation quest 13 years 5 months ago #21891
:dry:
Sure, i don't want to use a df01 buggy tower! ;) I'm just thinking about the strenght of the damper.
For sure i'll use a new df01 tower.
Vintage Manta Ray customisation quest 13 years 5 months ago #21892
  • Edou
  • Hopping Mad
  • Hopping Mad
Technically 65mm in itself should be fine. As long as you use good shocks. :y:
On a buggy it's important they aren't placed too vertically (that's on road) so some sidewards impact can be absorbed.
Vintage Manta Ray customisation quest 13 years 5 months ago #21894
  • Edou
  • Hopping Mad
  • Hopping Mad
I've tried 70mm too btw (that's on the rear) but they got the suspension close to the point where the dogbones start grinding inside the wheel axles (probably universals give more range). So you can't go too long either...
Vintage Manta Ray customisation quest 13 years 5 months ago #21896
On the rear you have to use long dampers 'cause of the weight at the rear. motor, battery, etc.
Vintage Manta Ray customisation quest 13 years 5 months ago #21897
  • Edou
  • Hopping Mad
  • Hopping Mad
True enough, you can compensate for that by varying hardness with springs and oil too.
Edit - and spacers or other shock adjustability (threaded ring)...
Vintage Manta Ray customisation quest 13 years 5 months ago #21898
Have a formula for this? ;)
Time to create page: 0.667 seconds
