Vintage Manta Ray customisation quest 13 years 5 months ago #21373
  • Edou
  • Edou's Avatar Topic Author
  • Hopping Mad
  • Hopping Mad
Yep, an on road front shock tower should work fine. :y:
Only thing is you'll have to use a "noseless" shell (so cut it off if it's not a TF)...
Vintage Manta Ray customisation quest 13 years 5 months ago #21374
How many times do i have to repeat that my MR shell doesn't have a noes anymore? :p
Thanks for answers! :)
Vintage Manta Ray customisation quest 13 years 5 months ago #21376
  • Edou
  • Hopping Mad
  • Hopping Mad
Length of the front dampers will go to around 65-70mm . ;)
Guess he got a new front tower too...
The following user(s) Liked this: funkindemup
Vintage Manta Ray customisation quest 13 years 5 months ago #21377
I've heard that this was caused by a fat french guy ;)
Vintage Manta Ray customisation quest 13 years 5 months ago #21378
Vintage Manta Ray customisation quest 13 years 5 months ago #21379
  • Edou
  • Hopping Mad
  • Hopping Mad
These Gauls are crazy...
Vintage Manta Ray customisation quest 13 years 5 months ago #21386
By Toutatis!
Vintage Manta Ray customisation quest 13 years 5 months ago #21510
  • Edou
  • Hopping Mad
  • Hopping Mad
Crap, those GPM motor mounts are really becoming a nuisance. :angry:
Plan was to take off the silvercan on the Humvee to replace it with the CR-Tuned.
But yet again one of the pins got stuck in the gearbox...
Apparently the thread lock sipped through the wrong way on one side.
Luckily I solved it this time with regluing (using J-B Weld steel epoxy) instead of mutilation.
From now on I will fuse the parts permanently this way before fitting any alloy motor mount again.
If I don't go for a one-piece specimen like waterbok's...
Anywho, moving on. Had a plan for a Mark II gearbox bracket for a while.
As a reminder, this is Mark I :
Using the wrong side of my brain, I placed the hole nicely in the middle last time :
But forgot to account for the bit on the side so that actuallly makes it 2mm off. :whistle:
A good reason to use my drill standard (not owning a vice for it yet) :
Besides a more accurate fabrication, I'm adding a spacer and washer :
Spacer was ordered for this purpose - to perfectly match :
On the left - the reglued motor mount while drying... :S
Working on that rear gearbox, I noticed a small crack on another screw hole.
And I killed the thread on the one remaining one (there's only three screws on top).
The gearbox is from the original Manta Ray I started this thread with...
So I'm gonna use some more steel hardened epoxy here and there.
:pinch:
Vintage Manta Ray customisation quest 13 years 5 months ago #21511
Maybe you've done too much torque on the screw to fix the gpm mount at the chassis? You can use a needle-nosed pliers with some cloth to loose it without damaging it.
Btw, want to see some horror-pictures? Beware, you have to have a strong stomache ;) img.photobucket...C/mrp8.jpg
Last edit: by funkindemup.
Vintage Manta Ray customisation quest 13 years 5 months ago #21513
nice work on the front gearbox, that might be a first. :y:
Time to create page: 0.197 seconds
