CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 12 years 4 months ago #29501
Got off my backside & investigated my Mu - yep it uses the forward sets of mounts, & yep I see what you mean about the chassis rails being not where they're supposed to be (Waaayy inboard).
Had a bit of a depressed-toned giggle at the lower link material, mounting method, shock mounting position etc, I can't imagine why they went out of their way to make something so "wrong" out of something that was so very nearly "right".
The later Fronteras (Vauxhall-mutilated Mu) were coil sprung/4-linked, but nothing like Tamiya's take on it.
Interesting point about the damper orientation - can't remember if my Fronty was like it, but both my Hiluxs had 1x shock slanting forward & 1x shock slanting backward on the rear axle. Thinking about it, it probably doesn't matter how upright they are as they're just providing friction, not providing springing effect - seized pivot bolts would do a similar job
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 12 years 4 months ago #29515
It occurs to me that cart springs with a fixing on each end need a floaty bit on one end so they can expand as they are compressed, otherwise the suspension will only have very restricted movement & put strain on the mounts :whistle:
As this thread is about CC-01 suspension & was prompted by my CC-01 build, I'm going to merge the two ... this could be carnage :blink:
edit - that worked ok so I moved the combined thread into "scratch builds" ... I see it now has a total of "1 views" :silly:
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 12 years 4 months ago #29521
Rainy season has arrived (last week of June, first week of Wimbledon) ...
Masking for grille was quite involved :whistle:
Shiny! :D
Clear stickers & transfers printed, wallpaper panels cut out & all clearcoated; interior window frames & stripes cut from vinyl:
Starting on trailer...
Cart spring suspension (should make eddrick happy ;) ); springs are 1/14 Tamiya truck, axle is 6mm tube bored out to fit M4 studding (a bit crude, but given the likely speed & mileage, good enough), brackets (including two cut & ground down for rear expansion links) are the last of my RCChannel bag; 6x brass spacers cut from tube are all but invisible in use; top spring pad is styrene, lower is aluminium; I'll remake u-bolts from M2 studding when it arrives :)
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 12 years 4 months ago #29526
C'mon, who would need a trailer to that huge camper van? :lol:
As usual, I can't believe the amount of quality work you put into your builds. :y:
-Lars
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 12 years 4 months ago #29527
Very impressive work Jon :y:
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 12 years 4 months ago #29530
C'mon, who would need a trailer to that huge camper van? :lol: ...
Someone with a left over back of a pick up body? ;)
The following user(s) Liked this: SteveU30
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 12 years 4 months ago #29541
More work on the trailer ...
edit - forgot to mention I had to make my own "F O R D" lettering thanks to swapping out the centre portion of the tailgate with the one for the "new" Blackfoot body :blush:
New frame built, suspension screwed on, load cover from body back forcibly removed, and the remains fixed on:
Insides paneled in, wheel arch covers (didn't come out as curvy as I would have liked) made & glued in ...
Spare wheel & toolbox started ...
Oops ... but it did make my mind up to make a proper trailer board rather than rework the original rear "lights" ...
Made (very thin) bits for sculpting the load bed + worked out spacing ...
Glued in ...
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 12 years 4 months ago #29552
More work on the trailer - I changed my mind about the lights, making something a little closer to the original; ribbing on the underside is a bit superfluous, lock & shackle more visible but very time consuming ...
It still needs filling, rubbing down, ironmongery removing, light lenses making & painting, primer, spraying, clearcoat, masking, load bed spraying, reassembly, details & decals, wiring ... other than that it's done :whistle:
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 12 years 4 months ago #29554
:woohoo: All in the week end!!!! crazy.
In France, Some years ago the mode was to cut a Renault4 f4 and use the rear cabin for a trailer :y: :y: :y:
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 12 years 4 months ago #29560
Been a long time since I saw a Renault 4 on the road ...
Anyway, look what I found :woohoo:
:whistle:
The following user(s) Liked this: waterbok, stingray-63
Time to create page: 0.296 seconds
