CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 8 years 2 weeks ago #52312
Doors on, working on the windscreen panel ...
In other news, having got through all the Post Office barely stick labels (on an A4 sheet) I've almost exhausted my supply of Avery 3.5" Disk labels (also on A4 sheets, copyright date on the box is 1997 :blink:) so had the choice of what to buy - I've gone for 1 label per sheet so I don't have to tape up the joins, and purely by accident, "opaque", which means they're blue on one side, white on the other... irrelevant, but I hope the multiple layers means they will peel off without tearing :)
The following user(s) Liked this: AJB
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 8 years 2 weeks ago #52315
  • Al
  • Al's Avatar
  • Hog Heaven
  • Hog Heaven
I love the detail of the vents on the front under the windscreen.
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 8 years 2 weeks ago #52330
Looking very good :y:
Labels is great to have to be able to send small parcels, I ended up buying some sheets with 8 labels on each sheet last time, because the other variants was stupid expensive.
The norwegian postal service have added a great feature to their system that I have not come to try yet.
From their site you can buy a stamp code, write it down the parcel, dump it in you letterbox, and postman will pick it up the next morning.
Think it only work for domestic tho.
But the rest of their postal service is rubbish, not working on Saturdays, and from 2020 they will only deliver post two days a week.
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 8 years 2 weeks ago #52331
These labels are strictly for printing out plans to use on card mockups, or sticking to styrene sheet and using as cutting guides :)
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 8 years 2 weeks ago #52359
Should be doing the front end body mount/bumper etc & the bonnet, got distracted by putting its "face" on ... yes, those are Wild Willy headlamps :)
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 8 years 2 weeks ago #52361
Sweet!
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 8 years 2 weeks ago #52362
Ah, you clever boy :y: :y: :laugh:
I may steal that idea one day..
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 8 years 2 weeks ago #52399
Still needs more work but the basic bumper shape is there ... looks slightly at an angle but when I measure it all appears to be square ... will have to give it a bit of a tweak as visually it's on the wonk ...
Working on the ribs to shape the bonnet (hoo) ...
Despite careful measuring, maths, scaling & cutting, I still had to make quite a few corrections ... waiting for it all to stiffen up/set before tidying:
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 8 years 2 weeks ago #52416
More work on the bonnet: edging & bracing:
2nd layer of 0.5mm sheet on:
Everything trimmed back to correct size, filler on leading edge:
Under side:
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 8 years 2 weeks ago #52417
Grille panel turned out to be a poor match in terms of shape, so I dremmelled the top down & have added extensions to the sides so I can make a 2nd attempt ...
