Spent 2 or 3 days making a 3D card mockup, having said previously that I wasn't going to
Aluminium standoffs: Sides, plus starting on the rear box: Cutting head has been unbolted for ease of moving about, but with it fitted & the card mockup, it's a monster - think two Clodbusters, parked in a T-shape |
Front box (engine housing, believe it or not) done ... the circular hole is not a porthole
Chunk of Aluminium left over from the wheels on my 1:12 Nichimo Lotus Europa (sold a while back) ... At this point I realised the main body should have been longer - hence the 10mm left over |
The following user(s) Liked this: VCR
Amazng work another time Jonny.
Fantastic execution, and so much work!
OH my, the Gerald Wingrove of the RC world is at it again !!
Absolutely excellent work, just an amazing and wonderfully non-typical RC build. Can't say enough how much this makes me smile. And good to see the old unimat at work, that's a mighty big piece of stock for that little machine!! Sure makes me miss mine, never should have sold it, even having a bigger machine I still miss just being able to put the unimat right on the table and make a part! I really should try and track down another one or something like it, make something... I don't know....hmmm Also, not to sound to daft, but I need to ask about the driver's body what 4x4 body is that?? It looks great too, by the way. PS. That Wingrove comment is not sarcasm, I really mean it, its amazing , I can't wait to see it in colour! From somewhere out in the wilds of central Ontario.
Last edit: by oldwilly.
Tamiya part # 54416 - modern re-issue of the driver figure first seen in the Toyota 4x4 Pickup (58028) & Blazing Blazer (58029) kits |
Working on the unloader ... tube is 3 layers of 0.5mm sheet, carefully bonded using a broom handle as a former ... a pin on the underside of the arm runs on a cam cut from aluminium tube, shaoed so its lowest point is at the rear (so arm is level in the "parked" position), at the highest point at the side (so the arm lifts in the "out" position). Problem is, while it works fine on the desk, it's not really robust enough for use on a moving vehicle, it's all a bit floppy in the parked position, and a bit too much torque is needed to get it to the fully "out" position. Plus, the shaft changes angle, so making it move under servo power is more problematic. TBH having it not fall off is most important, operable remotely of 2ndary importance, and having the arm lift, not very much at all - so some rework is in order.
