Sand Scorcher repaint 11 years 3 months ago #34877
Respect, Jon!
Awesome build and result!
Sand Scorcher repaint 11 years 3 months ago #34910
Respect, Jon!
+1 B)
Nice work.
Sand Scorcher repaint 11 years 3 months ago #34931
Santacruz picked the Scorcher shell up yesterday, and left me something else to fiddle with - a Mk.I Rough Rider, boxed with a few odds & sods that might come in useful. The plan is to give the chassis a thorough going over & Scorcher wheel/tyres out of my spares box, and the body will go on the shelf, maybe getting another SRB chassis at some point in the future.
In the meantime it does need a bit of attention.... it looks basically sound:
... but does have some significant damage on the left hand top corner of the white bit:
... plus similarly ground in dirt on the right side. Lower rear corners are better.
Now, if it was mine, because of the damage & the fact the white is just bare plastic & the red has been put on with no surface prep, I'd be probably be looking at a full strip down, repaint & repro decals - though it's a tough call, I've never had any used car in that good a condition to start with :)
What I'm going to try is a less invasive fix of the just the break on the left top corner.
First step was a wipe down, followed by removing the roof. Initially I had thought to just sacrifice the JT logo & work around the Bell & Auto Haus decals - but the more I thought about it, that just wasn't going to work, so they needed to come off, but still be useable again.
Heating with a hair drier & some delicate work with a chisel pointed craft knife got them off, and stuck on some double sided tape. Unfortunately the big Auto Haus one suffered a bit - but they was a spare one in the box (stuck to a Scorcher sunroof) that came off better.
Adhesive residue I cleaned off with IPA - which fetched off some more dirt...
After a sand with 120, 240, 400, 1200 & 2000, the surface was looking a lot better so I glued up the crack, clamping for a couple of hours to be sure it had set.
The spare Scorcher roof came in handy again - this time providing shavings to make a filler (mixed with DCM).
Next time I'll make it thinner - I'd started with the consistency I thought it ought to be & by the time I'd got it on the body it was drying really quickly ... I'll leave it to set overnight, hopefully it'll sand back a match & I can put the decals back on.
Sand Scorcher repaint 11 years 3 months ago #34932
Picked up the Sand Scorcher body yesterday and let me tell you guys what an unbelievable job Jon has done :ohmy:, looking forward to seeing how the RR comes out :)
Sand Scorcher repaint 11 years 3 months ago #34933
Jonny is the dead bodies Doctor
The following user(s) Liked this: waterbok, AndyAus
Sand Scorcher repaint 11 years 3 months ago #34935
Sand Scorcher repaint 11 years 3 months ago #34939
I suppose it was wishful thinking the join would be invisible, I think what's happened here is that dirt in the joint that I couldn't get to without dremelling the break right out & has leached into the fresh plastic... oh well, it was a bit of an experiment...
The question is where I go from here:
1 - call it done & put it back together
2 - clean up the other corners with the same techniques (less the filler)
3 - peel all the decals from the white area + prep/prime/paint
4 - full strip/repaint/repro decals.
Given the brief & that it still looks miles better than it did, I'm buying into #1 :)
Sand Scorcher repaint 11 years 3 months ago #34940
I'd go with option 1 ;) , would it be possible to cover the repaired crack Jon with a large Auto Haus and match the other side?
Sand Scorcher repaint 11 years 3 months ago #34943
for me, keep the original decals (as possible) and #4 method. But I am not the Doctor...
Sand Scorcher repaint 11 years 3 months ago #34944
I'll take a slight bit of artistic licence with that, but I think that's very doable :y:
I see where you're going with that, but I found removing 35 year old damaged decals time consuming and difficult, plus they do suffer a bit in the process ... it's ok for a very small number, but there's no way I'd want to do the whole body that way.
