Sand Scorcher repaint 11 years 3 months ago #34945
I am sure that you will find the best solution :y:
Sand Scorcher repaint 11 years 3 months ago #34949
Completely hiding the repair with the Auto Haus decal made it look too much like I was trying to hide something, it wasn't a natural placement & looked odd. Overall it looked better with a little bit exposed:
Sand Scorcher repaint 11 years 3 months ago #34950
Vast improvement Jon,damaged repaired but still keeping the vintage patina which I was looking for with that body.
Last edit: by Santacruz.
Sand Scorcher repaint 11 years 3 months ago #34958
:laugh: that is not choking. the result sounds very good.
Sand Scorcher repaint 11 years 3 months ago #34964
Vast improvement Jon,damage repaired but still keeping the vintage patina
Yes great result :)
Santacruz' Sand Scorcher 11 years 3 months ago #34984
Mk.1 chassis (which will go under the Scorcher shell), plus vintage wheels from my spares box (originally from a Grasshopper so the screws on one pair have slotted heads, the others have crosspoints):
Dismantling the Rough Rider wheels stalled at the fresh superglue :whistle:
Apart from the missing switch boot (which took me serveral days to notice - doh!) the chassis looks very complete - but it is absolutely minging:
I was warned about the missing pin on one of the camlocks being replaced with an R-clip - but I just pulled the clip & the camlock rocket propelled itself across the bench :whistle: When something goes behind/under my bench it's usually gone forever, so it's not surprising I couldn't find the spring :( I know I have a spare one, I'd just rather not have had to use it.
Radio box will clean up I'm sure, but there is evidence of heat related warping - a little to the top & a lot on the underside - overheating battery I guess?
Wiring could stand some "refreshing":
Nice, period Futaba radio gear, bot note the fragment of radio box plastic. I couldn't find a missing area on the box parts :huh:
Santacruz' Sand Scorcher 11 years 3 months ago #34985
Well nuts have completely had it... they were working well enough, but disintegrated while I was trying to get them out. Motor/resistor wiring grommet is still just about serviceable:
That gearbox isn't looking any prettier (UJs are the most worn I have ever seen, and the grub screws weren't tight, maybe suggesting some parts swappery?) ...
... but the covers are reusable ...
... and the insides look pretty good:
Front right corner has some issues - headlamp tab broken off, I don't think thin dual springs are OE (other side the same), odd screw in top arm:
Shock bushings: 4 are marginal, 4 disintegrated:
I'm sure the bumper is the correct black one, but it's worn, bent, cracked, glued, and been painted over without brushing the sand off first ... Initially I wanted to just replace it with a re-re Fighting Buggy one, then I thought if I can't do that I'll strip the paint off, but TBH I know it'll be a horror show under there and that would probably take it from ugly to unusable - now I'm thinking just throw a wet wipe at it & leave it alone :sick:
Parts divided by material, most of this will go through the Ultrasonic tank - but that's a job for a (future) rainy day, I just wanted to get a head start on getting any required bits in :)
Santacruz' Sand Scorcher 11 years 3 months ago #35009
Well yesterday was a rainy day - it rained continuously for 18 hours :whistle: - so time to get on with preliminary cleaning...
A reminder of how yukky the bits were:
Filth started lifting off immediately in the ultrasonic tank:
... and after 30 mins:
After a going over with a toothbrush, another session in the tank, plus rinsing & drying:
(note the variations in colour)
These bronze bearings didn't want to come out initially, but after cleaning I could see it was just blue Hylomar (and possibly evostick, or sealant) holding them in so they could safely be drifted out from behind & the void cleaned...
Gearbox had two type of sealant on it - carefully applied white, and orange put on with bog knows what...
Some parts of the gearbox were suspiciously sparkly & rough, like they'd previously been media blasted?
Santacruz' Sand Scorcher 11 years 3 months ago #35010
Front springs are definitely home made:
A lot of the rear end components have red paint on them:
I'll give the Rough Rider rear wheels a quick skin on the Unimat to tidy them up ...
Extra plastic bit mystery solved:
This method usually works for bearings - drip on 3 in 1 oil & leave overnight, draw off with capillary action from underneath with tissue or rag, repeat until clean - these are surprisingly clean.
All the other bits (excluding the electrics) have been through the tank too :)
Santacruz' Sand Scorcher 11 years 3 months ago #35011
Time to create page: 0.213 seconds
