Those door-internals are just crazy, Jonny! Really cool!
And I've never seen anyone reduce diameter on rubber tires before! they look excellent! Only negative I spot is that the split window proportions does not look right to me. They are too big. (and you're missing the rubber grommet between body and chassis, but that's ok Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
That's crazy!!!
WOW !!!!!!
JR you are a master craftsman sir |
TBH I think scale accuracy went out the window the moment I started with a Scorcher body (too wide, not long enough etc) ... rear windows are still "wrong" with the (planned) "rubber" strips in -but then, so are the slot vents Taken off the 12mm hex mounts: Hubs/brake drums & front axle started - everything is still loose so I can tweak before gluing up: |
Awesome, no other words to describe it pal
It will be a rc? Or just an amazing scale like a pocher?
It was only ever going to be a static model
