Some thoughts....
The ball would be a pig to do by hand, would modifying a (Broken) original axle be a viable option? - maybe a sleeve that fits over a shortened axle & holds the bearings, OR maybe reclaim the ball part from a busted axle & make it an interference fit on a new tube? There are ball turning attachment designs out there, but I just haven't got time to build one at the mo.
I think I will have a go at having it 3D printed first, just to see if it will fit/work. but not in a hurry with this project, its just an idea i had to get the M38s that are beyond repair up and running again. (and the hex conversion would be a solution for those that are running out of tires) |
Things I would buy and build if I had a suitable toolshed for metal working.
Lathe Mill and then make things like this Ball Turning Toolpost (Steve Bedair's ) |
I haven't seen a ball turning tool like that one before, but there & again it's not much use if you wanted to do a ball of a different size/radius - there doesn't appear to be any adjustment on it....
Of course, these tools are for model engineers, the parts are usually 1-offs & only have to look right, I bet he can't make another dimensionally identical part! For Willy-balls, you'd need a method that is repeatable & a way to position/measure the ball fairly accurately. Without CNC, I would say you'd need DRO to position the ball, & either a tool ground with the correct radius, or a dedicated size (Or adjustable) ball-turning attachment similar to that in the vid. All time consuming & not financially viable to do as things to sell - it would be easier/quicker/cheaper to find a way to reclaim/modify broken originals. Either that, or find a source of cheap, correct-size balls to fit to a plain tube, to fabricate the axle rather than try to machine it out of solid bar. Why don't you invest in a (Chinese) mini-lathe if you fancy having a go Waterbok? They're not hugely expensive & hold their resale value well if you decide you don't want it after all. New ones are only around 300-400gbp & they're small enough for the smallest of shed benches (I'd considered getting one for doing small bits indoors...). Be aware that the model engineers love them (Which is why they hold their money) & a new one won't be much more expensive than second-hand, but it won't be worn out/broken like a 2nd hand one
its adjustable, the part that holds the cutting bit can be moved from and to the center of the tool.
its used in the second video and also can do concave problem is, the sound isolation of my 'workshop' (basement) aint so good, the misses already complains when i am drilling a small hole in aluminium or use the hacksaw or a file. Dont want to create a row with the other tenants. |
How do you know what radius you've set, or how much you're adjusting it by? How do you set the tool at the correct radial distance from the centre of the workpiece? - unless you know these things, you'll cut a pellet rather than a sphere.
It's a nice compact design, but if I ever get around to making one, I'd have to think about how to sort out the above problems - possibly "setting-tools" rather than graduated adjustments (ie, so you "set" the thing at a repeatable known dimension & work from that)
You might be able to fit a micrometer head to the sliding part (probably with something to lock it in position).
If you wanted to do that I have some micrometer heads that you could have. They were returned from a customer because the mounting was wrong (plain instead of threaded) and were replaced by my supplier FOC (their mistake) so they don't owe me anything. |
Yes, the design/drawings I have here use a mic head for adjustment.
Cheers for the offer Martin, but I shouldn't worry, it's very unlikely I'll get around to making one any time in the near future! Don't bin them though, I'll have them if that's going to happen
