Have you got anywhere with this? I've only seen 5 pairs of vintage balls myself (boom! boom!
A while back eddrick mentioned balls, how about something like ebay item # 271381900132 (18mm nylon balls intended for machine lever ends)? Bored out (& possibly narrowed) these could slip right on a custom made bit, I don't see it would be a problem if the ball wasn't fixed down, though an interference fit would probably be better |
Those are exactly the balls I had my eyes on for a while now
To be honest, project has been on a standstill for a bit but still thinkering with the idea. (didnt have time to play with the unimat either |
I mean the front metal piece that you've change with the hex. i need the same piece , but in sicily it's hard to find and i don't know the exact misures..
can you help me? c'mon UP FOR WILLYS PLEASEEEE thank you |
Do you mean the Frog wheel adaptors? |
No I think he means the front steering knuckle, problem is i got no idea which brand it is (might be kyosho).
Got it in a batch of parts. Clacchisi where do you live in Sicily? |
Hey guys first of all thanks to answer to me
I live in catania. and what i looking for is the exact misures of the front hub, the metal part in the picture. I found an hub on ebay , with axel and bearing , a complete set i mean(and that's all i need) but i don't if the misures are ok ! and all shops in my city try to rob my money but i know the cost is not expensive actually |
I've found that most 1/10 steering hubs are very close in measurements, if only a washer to space or file to fit If you can't fix it with a hammer, you've got an electrical problem mate
