hopping up a vintage grasshopper 14 years 10 months ago #5145
With the weight decrease I'd certainly consider it a hop up.
And I estimate aluminium would be strong enough...
Copper might be a bit soft but as long as it doesn't deform, it'll do of course. :)
hopping up a vintage grasshopper 14 years 10 months ago #5147
maybe a solid aluminium bar would be better, still lighter than the steel one.
i could make 5 out of this.......
www.ebay.co.uk/...1620wt_942
Last edit: by agemax.
hopping up a vintage grasshopper 14 years 10 months ago #5148
Sounds like a plan. That'll still save 60% of the original weight. :cheer:
hopping up a vintage grasshopper 14 years 10 months ago #5152
Of course, leaving it out entirely would save 100% of the weight ... but I tried that on a Lunchbox & it had the annoying habit of converting itself to a long wheelbase version after even minor impacts :silly:
hopping up a vintage grasshopper 14 years 10 months ago #5153
i really dont think changing it to aluminium will have that much effect on performance or handling etc. maybe some sort of linear bearing at each end of the shaft may help the smoothness of the suspension and stop the end plates from wearing. will have a looksee tomorrow if anything can be done
hopping up a vintage grasshopper 14 years 10 months ago #5195
right, so planning ahead, i need an ESC which i think i will go with Mitroniks as i like it and trust them. next i need a RX and a steering servo. any suggestions anyone, new second hand Tamiya or aftermarket? as long as its not too expensive :cry:
hopping up a vintage grasshopper 14 years 10 months ago #5198
Maybe you could look around here :
Hobby King
They have a 2.4 GHz Tx/Rx combo from their own brand for $23 :
This one
:blink:
Edit - posted that Rx a bit premature. Doesn't seem to work quite well with cars when you look at the controls. :S
But five bucks for a metal geared servo is pretty awesome :
Servos
hopping up a vintage grasshopper 14 years 10 months ago #5199
One more addition - the German warehouse :
Das gibt es hier
hopping up a vintage grasshopper 14 years 10 months ago #5309
Am I correct in the assumption that the Hornhopper will get oil shocks and the second build a regular setup?
In any case - don't go shopping for shocks just yet. ;)
hopping up a vintage grasshopper 14 years 10 months ago #5310
yep, my plan is to fit CVA shockers on the hornhopper then just fit the standard hopper shocks onto the other build
Time to create page: 0.327 seconds
