Re: Scratch building scale accessories, + weathering 13 years 1 month ago #24844
I just read through the topic, i guess you also have a background in static modelling? Very nice work! :y:
Not really, other than Matchbox plastic plane kits in the late 1970's :)
Re: Scratch building scale accessories, + weathering 13 years 1 month ago #24846
Ah, those where the day's, they always ended up immitating the battle of England in the garden :y:
Scratch building scale accessories, + weathering 13 years 4 weeks ago #25413
I can't believe it's been over a year since I last built anything like this... anyway, I got back in the mood & so started on a roughly 1:10 scale styrene, stylized (or, not entirely accurate) version of a Colchester "Bantam" lathe ...
Starting on the stand ...
Lathe bed parts ...
Bed assembled, motor/gearbox housings, belt cover ...
Bulk of chuck turned from DIY 18mm square bar ...
Couple of turned rings added, + chuck jaws ... I thought these looked very poor, so turned them down for a better match to about 1/2 the size ...
Shaped & sanded, 60, 240, 400 & 1000 grit ...
All the bits so far glued up, splash guard added ...
There's still an awful long way to go yet, but the basic structure is there.
Scratch building scale accessories, + weathering 13 years 4 weeks ago #25414
Really outstanding this!
Scratch building scale accessories, + weathering 13 years 4 weeks ago #25420
:huh: Jonny I am not sure that you are a real human :blink:
Better than DAVID VINCENT. We haven't seen them but we have an on TB "les envahisseurs" :silly:
Have you the small finger straight?
Scratch building scale accessories, + weathering 13 years 4 weeks ago #25445
Started on the detail bits:
Bed rails are bits of square dremmelled & sanded down:
Top tray parts ....
... & assembled:
Basic handwheel shaping (on the lathe, from 3mm sheet):
Some drilling, dremmelling, filing & sanding:
front skimmed down, spacer added on back:
Tailstock done:
All those bits fitted, along with power box, stop/start buttons, drawer handle, brake bar, ground bolt tabs, 2x info panels, cross slide drive teeth, power feed, guide rails & trim on top of the splash guard ... just a load of levers, cross slide, tool post & lamp to go ...
Scratch building scale accessories, + weathering 13 years 4 weeks ago #25447
:ohmy: :woohoo: :y: :y: :y: :y: :y: :y: :y: :y: :y: :y: :y: :y: :y: :y: :y:
Scratch building scale accessories, + weathering 13 years 4 weeks ago #25458
amazing
but can you include a MM or CM ruler so that we can see actually how big they are.
You said 1/10 scale but there is nothing to compare it with
thanks
Hay Ewe
Scratch building scale accessories, + weathering 13 years 3 weeks ago #25467
amazing
thanks
Hay Ewe
Each of the squares on the cutting matt are 10mm (1cm) :)
Nice work JR :y:
Last edit: by AndyAus.
Scratch building scale accessories, + weathering 13 years 3 weeks ago #25482
@ hay ewe - andy is correct, but I put a 6"/150mm ruler in too :)
Cross slide was redonkulously fiddly & time consuming...
Looking good so far - I cheated a bit with the control levers, obviously they're sewing pins ...
I still have to do the coolant pipework & anglepoise lamp... I tried the body 3 times in styrene but it just wasn't happening... doing it in aluminium brings it's own problems, but hopefully weight won't be one of them: hollowed out it weighs 3g.
Time to create page: 0.206 seconds
