Jonny, this is outstanding work!
I've finished the painting, I still need to find some "mains cable" & make a plug for it, but it's basically done - I'm quite pleased with how it turned out
Top half is XF-21 Sky (sky? Details are X-11 Chrome Silver, XF-56 Metallic Grey, XF-16 Flat Aluminum, XF-69 NATO Black, X-31 Titanium Gold, X-32 Titanium Silver, X-14 Sky blue, XF-85 Rubber Black, XF-9 Hull Red, X-7 Red and X-28 Park Green. Weathering is strategic use of watered down X-19 Smoke. Decals were hand drawn in Paint Shop Pro, printed on clear transfer paper & sealed with X-22 Clear before being wetted & applied. |
I've been thinking about that for a while, a basic 3-sided (+ base) shed/garage ... it would need to be oversized so I could use it as a photo backdrop - and also be demountable because I don't have anywhere to store something that big. Scale brickwork or blockwork would be nice, but TBH I'm thinking more in terms of scale 8' x 4' sheets of plywood |
Install a pulley system so you can drop a diorama set from the ceiling If you can't fix it with a hammer, you've got an electrical problem mate
Absolutely to job!
I had to look twice to check if you had popped in a picture of the real deal... Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
I've been looking at other people's garage dioramas, the ones that are most successful as scale backdrops (i.e. you can get a photo that shows nothing but car & diorama) are pretty big - twice the length, width & height of the car in them
I'm going to rule out getting a clod in one, the question is whether I do one at Bruiser scale, or "merely" Scorcher scale ... either way it's for the future, but in the meantime I had a go at a bench grinder: Start was to turn down some of my DIY square styrene bar to round ... ... then machine steps & tapers, + make the grinding discs & cover outers: ... then spacers & end caps. I also drilled & tapped the ends of the body, they won't be staying screwed together, but I thought if all the outer bits already had holes in them as an artefact of how I made them, I might as well take advantage of that for alignment purposes: All the bits so far assembled, + thin strips to complete the covers: Starting on the base: Base nearly done ... Buttons & clear covers ... I need to find some shorter screws ... Paint & transfer done, + m2 x 4mm screws |
