Bodyman!
Your advices are excellent. Around me, no garage want to sale me paint. I had only 2 oportunities to paint abs bodies with car paints, the clio 4 metal red. I never try on lexan. Can the car paint work with an airbrush? |
Are you up for writing/photographing an article to go on the TamiyaBase front page? Lars and/or I are quite happy to do photo croppy/resizing/watermarking + formatting/puntuation etc, it's the raw material that counts I can understand people being skeptical about your method, as it's completely contrary to usual doctrine - but in my experience, polycarbonate is problematic anyway - a lot of paints that are _supposed_ to work on polycarbonate really don't... In my experience only Tamiya PS sprays (with proper prep & lots of thin coats) seem to stick properly, Tamiya PC brush paints (no longer available) when brushed on would crack & peel on any impacts + needed a lot of coats, Humbrol Hobby Spray (which it supposed to be good for both polycarbonate & styrene) was very sensitive to curing time between coats, and colour choice (some colours would fall off if you so much as farted in their general direction), Faskolor (when brushed) was worse than Tamiya PC paints (I never tried airbrushing it). |
I made several bodies with createx paint. And I had the best results on poly bodies. Same on styrene. The only matter is the price of bottles...
The airbrush is very easy to clean with hot water. That is automotive paints. |
Last edit: by stingray-63.
Hey Johnny , Yea ill do a photo shoot of the alfa being painted when it arrives in a few weeks. In my honest opinion its always too little coats or people not prepping enough, Its 95% prep 5% paint, The only time i have issues is when i get ansy like yesterday and peel my masks too soon and rip up a corner from not angle pulling, I usually just touch that up with a brush or ill remask and spray. Thin even coats with enough drying time between is key, I usually go through a full can of paint per body, and the best results i have are using Dupli-color paint. I think a lot of the model guys expect 2 to 3 coats to cover everything, In auto the deeper the paint the deeper the look and shine. I will do my best for an article but will defiantly get you guys to edit it for me but no probs on the painting pics.
Nice bearings
The following user(s) Liked this: BCM06
Depends on the complexity of the sheet & the chances of getting bits mixed up, I often make a copy of the sheet before I start, & use tape (Tamiya 6mm masking) to hold each decal in place on that, completely cutting out one at a time. |
I cut each decal one per one directly during the deco time. And I try to put them number after number.
The hardest were my TGX 911 GT1 and the D2 MERCEDES Klass C DTM, The delta HF MARTINI and the JECCS CIVIC. |
