Vintage Manta Ray customisation quest 13 years 7 months ago #19861
:y: I love the parmarlboro team
Vintage Manta Ray customisation quest 13 years 7 months ago #19873
80s/90s McLaren F1 Style ;)
That was a nice time with Prost & Senna.
But also in Ralley and Touring they had this red/white thing.
Vintage Manta Ray customisation quest 13 years 7 months ago #19896
:y:
I would like to make a marlb... deco. Absolutely not real but on a vectra,...Maybe it will be cool.
Vintage Manta Ray customisation quest 13 years 7 months ago #19901
That's my no-malb malb, staying at the foot of my pc monitor ;)
But i have to get some malb stickers to build up an original. I'm also thinking about to get a Tamiya non R/C scale model to color it. I have seen an amazing video at youtube, a japanese guy colouring this model very very nice!
Vintage Manta Ray customisation quest 13 years 7 months ago #19905
:) :y:
I think that you just have to use X7 red paint and for the used running version, you can use oil pastel. It is cheaper than pigments. I use this method on my militaria die casts. White for use, black and brown for running marks.
Vintage Manta Ray customisation quest 13 years 7 months ago #20266
  • Edou
  • Edou's Avatar Topic Author
  • Hopping Mad
  • Hopping Mad
:woohoo:
For the Humvee :
And for putting the new FRP plates together :
:cheer:
Vintage Manta Ray customisation quest 13 years 7 months ago #20267
  • Edou
  • Hopping Mad
  • Hopping Mad
In the leaflet of the CR Tuned it is specifically mentioned that it has 0 degrees timing...
They might be a good alternative for Bullheads and such as well.
A lot of torque and about the same rpm as a silvercan.
It will probably even give such a car a bit more top speed, as this motor would be more efficient under load.
And the motors wouldn't be working against each other, making it taylor swift around...
B)
Vintage Manta Ray customisation quest 13 years 6 months ago #20441
  • Edou
  • Hopping Mad
  • Hopping Mad
Bit of progress on the Humvee... next up was the front gearbox. Take it apart first :
Cleanin' out dirt :
My little helpers - feeler gauge for shimming and the E-clip tool :
Rubber sealed replacing metal shielded bearings :
The aforementioned shimming of the C hub (0.4 and 0.5mm - quite a lot) :
Hardened ball ends instead of regular ones :
Suspension arms finished:
Vintage Manta Ray customisation quest 13 years 6 months ago #20460
Nice suspesion arms! A 35T in a ta01 Gearbox? Do you want to build up your own very special crawler? ;)
Vintage Manta Ray customisation quest 13 years 6 months ago #20472
You'd be surprised at the speed of 35T motor - I've had them in two scalers, thinking they'd be a good compromise on speed, but had to swap them out (for 55Ts) as (offroad with low gearing) they weren't really any slower than a silvercan :blink:
Time to create page: 0.178 seconds
