He has all options for the unimat like "gears maker" I need materials too. sure that I will do some training. That is a tool I want use. |
sure
It's chatter caused by too much pressure at the end of a pass or two - ordinarily I'd leave the pass a bit short & set up to go in & out to tidy the edge, but it wasn't really necesary as it was all going to get turned off when I did the taper anyway. |
Not quite... I used Lars' dimensions, the drawing wasn't correctly proportioned as I used Yellowcats photo as a starting point. I've done another drawing using my faux bodypost as a basis (and Lars' dimensions) so the proportions will be a lot better: It's not much of a solution either - total time to make it was nearly 3 hours (most of it on the Unimat at 0.025mm per pass I'm now thinking more on the lines of this cheap generic one - it buzzes like a cheap Dremel clone at peak revs, but it costs a quarter what the Proxxon does |
SL threads are 1mm pitch so 1 turn on the handwheel on the Unimat = 1mm, each has 20 graduations so 1 notch = 0.05mm ? I've managed much deeper cuts before on alloy, certainly 4 notches (0.2mm) or even more when doing initial sizing or facing cuts close to the chuck, but in this case it's a comparitively "long" bit unsupported at one end, a heavy cut there is inviting the bed to bend & chatter. Overall I'd rather do it a bit slower (half a notch or 0.025mm) than have to do it twice. There might be a better order to do things in to allow deeper cuts, but it seemed logical to me? |
You already have a tail stock which you add the chuck to, How about picking up a tail stock quill to support you material ? If you can't fix it with a hammer, you've got an electrical problem mate
