Project: Dirt Trasher customisation 13 years 2 months ago #23679
Hi guys,
I run 4 packs using the ball diffs. Huge difference. The car is much more drivable with the brushless/lipo power.
The last thing, I hope :), I have to tune is the shocks.
  1. They are too stiff. The rear tower mount is already broken on the side where the screw can't have a nut. And the front tower mount go through the same problem. The two screws popped out at some point on my last run. I will try to put the springs that come with the original kit.
  2. I have a problem with one cap. It keeps popping out. I think the thread is broken because when I try to lock it, it skips and the cap get loose. Maybe I will try different solution like this . They are cheap, so why not trying.
Project: Dirt Trasher customisation 13 years 2 months ago #23680
Good to hear the ball diffs work well. :y:
Is that shock cap problem with the GPMs? Sounds kinda weird for alloy...
The other issues are quite typically DF-01. Softening the suspension should indeed spare the plastic more.
Re:Project: Dirt Trasher customisation 13 years 2 months ago #23682
I got a couple of the plastic rear shock tower i think if you need any?
Project: Dirt Trasher customisation 13 years 2 months ago #23683
Not sure if they are genuine GPM: link .
I will try to put some silicon tape to see if it helps.
I have to make the car bottom up more easily so the chassis could absorb more.
Re:Project: Dirt Trasher customisation 13 years 2 months ago #23684
Thanks for the proposition. I use the carbon fiber tower. So no problem on this side. My problems comes from the attaching points on the gear boxes, front and rear.
Project: Dirt Trasher customisation 13 years 2 months ago #23685
Or maybe thread lock? The tough kind...
Not a fan of RC Damper anymore. The alloy uprights I got from them look exactly like GPM but are just not up to spec.
Tbh, I think you may have overpaid on those shocks. They probably buy 'em for 2-3 euro a piece.
That's what these cost :
Spring on those was hard as rock too.
Best place for GPM stuff in my book is Asiatees .
Or you $50-60 you could go G-made :
B)
Re:Project: Dirt Trasher customisation 13 years 2 months ago #23686
Ah ok, already gave away one of those at funkindemup. He had the same problem ;-)
Project: Dirt Trasher customisation 13 years 2 months ago #23687
Bummer on the new blue gearboxes. :dry:
I'm using 2x12mm countersunk on the front (GPM on road shock tower) - hoping that'll give a bit more bite...
Project: Dirt Trasher customisation 13 years 2 months ago #23688
Yep Edou you're right. Those shocks are highly overpriced. I've should have look better before buying them. But I was not sure how to find shocks that would have fit my DT.
Those Gmade shocks are great. I will continue to look around. I will probably put 75mm front and 85 mm rear.
Project: Dirt Trasher customisation 13 years 2 months ago #23690
Those lengths might be a bit short. The CVAs on the Top Force are about 87mm front and 92mm rear.
Best chances to get an easy fit will probably be 85-90mm...
Of course there's a bit of room to adjust length (damper spacing, different lower shock mounts) but not a great deal.
If I ever get the chance, I'm thinking of putting Big Bore (extra beefy) shocks on my FRP car. B)
Time to create page: 0.377 seconds
