Project: Dirt Trasher customisation 13 years 4 months ago #22491
Oh yeah! I've already put two longer screws and one with a nut. And even with the broken plastic it is a lot stiffer.
I've also noticed that when I start at full throttle the car does not go straight. I think it might came from the diffs. It seems that I have a wheel which spin faster than the other, at the rear at least. I don't know if going to ball-diff can be a good option.
By the way. What kind of maintenance do you make after a run with your DF01?
:y:
Maybe you could even melt the part back together (gently) with a soldering iron...
Don't think a gear diff would be the cause of the wheels turning differently. Would sooner be more drag on one side of the outer drivetrain (dogbones being forced under an angle or broken ball bearing in one of the wheel axles for example).
A ball diff is cool but requires quite a bit of maintenance.
You could try and put some thick grease in the (rear) gear diff first, that'll give it more straight line stability.
Maybe have a look at the angle of front wheels too, and give them a bit of toe in...
Edit - I just dust off with a brush after a run and do a partial rebuild now and then. Don't run 'em a lot though.
Project: Dirt Trasher customisation 13 years 4 months ago #22493
Well I don't have a soldering iron. But the holes are a bit stretched too. I even noticed that the right screw has been bent!
Yes I will try to put more grease inside the diff when rebuilding.
Project: Dirt Trasher customisation 13 years 4 months ago #22497
something about differentials (in german :whistle: )
Project: Dirt Trasher customisation 13 years 4 months ago #22500
Thanks for the link. I only understand the basis of german so it go way beyond my capacity. :) But Google translator may help a bit.
Project: Dirt Trasher customisation 13 years 4 months ago #22501
try watching allo allo! ;) thats how I picked up german, french and english (all whiz a phunny ackcent)
:laugh: :laugh: :laugh:
Project: Dirt Trasher customisation 13 years 4 months ago #22502
Ho! Also about the ball-diffs. The DF01 has no clutch. And what I saw about ball-diffs. It is possible to make them act like a clutch. So that is my idea too. Not sure though.
Project: Dirt Trasher customisation 13 years 4 months ago #22512
Even if you screw the diff together all the way, it will still somewhat act as a limited slip diff is much power is applied.
No such thing on a gear diff...
I've been making variations in the diff tension but that takes more maintenance to check it didn't loosen after running.
Tips and tricks on (re)building a ball diff
Still needs to create the additional notes for that video...
The official Tamiya way (on most of the descriptions) would be to tighten it completely.
Project: Dirt Trasher customisation 13 years 4 months ago #22513
Very nice video. :y:
At the moment I will keep the gear diffs. First I will try to buy some better tires to have better traction. Then I will see if it changes the behavior.
Project: Dirt Trasher customisation 13 years 4 months ago #22514
If you stuff the rear gear diff with thick grease, that'll definitely have an impact on straight line stability too. :y:
DF-01s can be very light on their feet with double cera-greased (or similar) gear diffs...
To make sure there isn't something dragging the car on one side, manual checks to get a feel are always a good thing to do.
Project: Dirt Trasher customisation 13 years 4 months ago #22515
At the moment I used a Facom lithium grease which is pretty thick. I will put even more in the rear diff.
