Love it Bro!!
Thanks a lot. Me to. Better picts later but it needs bbs bee nest gold rims and the gold line to be a 4L 6 inline limited one...... ( honnestly out of box it is already lovely) I have the aloy steering bars to put on it to. An unnecessary option but nice. My mn82 lc79 is out of box and It is my runner since up to 1 year. My grandson run it regulary. The only issue are the aqs. Same my 3800 mah charged by the imax b6 is killed after a little of runs....
Edit: it will have some details and accessories maybe this week-end. 😉
Attachments: |
This would appear to be a normal "New" Attack R TX of the FM 40mhz variety, but has been cross-pollinated with an Absima 2.4 steerwheel set & internal NiMH battery pack.
It arrived with an RX, original Absima manual & a charger. I had been hoping to open the TX up to see what had been done to it, but everything seems to have been glued up (including the empty xtal case & now non-extendable antenna & I don't want to force it - at least not until the battery fails. Attachments: |
Nice score !!
I saw that Acoms but dismissed it on the basis I REALLY don't need more TXs. My Mk.IIIc has arrived & I need to sort through the spares to turn it into a complete boxed set. It came with a very clean box, TX, servo fittings & pennant plus a couple spare crystals. I have manuals, receivers & battery boxes, not sure if I have a couple decent AS-7 servos to complete the set though. Caprinut is building a similar "Brundlefly" Futaba using a different 2.4 (I forget which)
Last edit: by BlacqueJacque.
I thought they were katanas....🙃
I hope they work out My experience of the XR311/Cheetah suspension was that the square fittings in the wishbones would have really fine cracks at the corners - you think you were getting somewhere with setting up the suspension then clunk, the torsion bar would jump round 90 degrees & you'd lose all the springing
I can see that |
