Makes sense....
No thought as to how to get them out again when they're stuck in the smooth mounts though! (Had a semi-issue with that on my Astute). I prefer the look of the curvy bits though, adds some refinement
I dug out some of my old school books (mechanical engineering/werktuigbouwkunde)
So fitting a bearing on BM1 the advised tolerance (in µm) on a small diameter axial bearing axle would be j6(+7,-1) but in our case a h6(0,-8) or even f7(-10,-22) would be more practical. |
Yes because you normally aim for a bearing to be the best fit it can be without distorting the inner race, which requires a press & fine surface finishing of the shaft. You'd usually only bother doing this with posh high tolerance or heavily loaded bearings though (To maintain concentricity & reduce risk of deformation under load)
We're working with machined-only ally & the bearings are to be loose enough fitting that they can be put on (Or removed) by hand. 0.02mm & below are generally accepted as grinding tolerances for production manufacture. You can specifically cut 0.01 on a really good unworn lathe (Or with lots of patience), but for close tolerance (Micron) stuff it's usually a case of grab the wet-n-dry & go by feel. Been there, done that, machining at the point where the the part won't fit, you tickle it & it will, yet the calipers still read the same number (So you're removing less than 0.01mm). Needless to say, I won't be going quite that mental doing these! 0.02-0.05 clear will be fine. Impressed you know about number/letter fits - any drawings at work with that kind of annotation usually get handed to me by blank-looking draughtsmen! Have a look at surface finish & welding symbology too, those are others that have the draughties baffled!
sorry
The sets on Tamiyaclub that you had made seemed to be popular enough, regardless of the imperfections.
I'm just hoping eddrick gets into the swing of fabricating these ones (and still has time to eat and see some daylight)... Getting quite excited about the idea of building another FRP car. |
i hope that they are not going to be expensive
Last edit: by kemmatech.
Do you know these guys (gotta click a little forward on the RC car image)?
www.fibre-lyte.co.uk/ You'll have a price comparison at least. Eddrick, I'm gonna throw these (suspension shafts - an unrelated parts bag) in the mix. Would they be hard to make? |
