And a lot of work in perspective!
Yes that's right. But As you will see I had no trouble using them. |
Looking good.
Edit - can't really tell if the ball end on the left (of the picture) is really sticking out much but I had a problem at first with that hitting the gearbox. Might be worth taking a look at before you reassemble it all... |
@Edou: I've just checked this, and the ball connector don't stick out really much. There is still room. This should not be an issue.
Kinda off-topic, but I want to change the steering servo which is weak and slow. So I looked, but there is so much choice from 10€ to 200+€??? I have no clue how to choose a good one but not too expensive. I think it worth upgrading because with the brushless I have a very poor handling. So any helps appreciated. I've heard that Savox is good brand: this one should do the trick? |
Last edit: by BraindeadBZH.
