Any 27mhz AM RX will work, for example:
or but not this one, as it doesn't say BEC on it: |
Yep, that's fine |
I like the one at the back, Looks cool in black and the rims look cool too.
My Projects:
i have a 540 Mabuchi(?) motor for the second build. 3 questions.
1. am i right saying i need a 18t pinion 2. what are the size and length of the screws that secure it on the car 3. there is a resistor on both connectors where the wires solder onto, one has snapped off.do i need it and if so what size resistor do i need to get thanks |
thanks Edou.
i received the aluminium bars for the hornet suspension today. they are slightly thicker than 4mm, 4.2 mm to be precise so i will see if they fit ok, if so pm me your address and i will get one in the mail to you. and Jonny, my bits came today as well thankyou SO much my RX also came today so all i need now is to sort the motor out and it should be up and running. its just like christmas again
