Just had a look through my Cheetah manual to investigate the possibility of coming up with a rolling chassis out of those bits (Couldn't help myself!), & it appears the only bits missing that would cause me problems are E6, E11,E15 (Rear suspension bits) W6 (gear) & G2 (Gearbox cover, yey). The rest I'm pretty sure could easily be made (The missing bits too, but not sure I could get enthusiastic about that). Gonna have a wander about on the net to find out what the chassis is similar to/based on (For ideas of what body could be suited to it).
What sort of money are we talking about for the lot?
How does a tenner grab you? I should point out all the bits (apart from a couple of bits I mentioned) all all used, but serviceable AFAIK |
Cool, ok, I'll be able to lay in it all & writhe about if nothing else...
Any idea of P+P on that? PM me a Paypal address
Postage still |
Forgive my ignorance, but are you taking the mickey or is that the recommended way to clean a motor? I always thought electricity and water don't mix well |
Interesting. I had heard of running motors in in water, but not cleaning them.
If one did not own an ultrasonic cleaner, would it be helpful to run a motor for a short while in the soapy water to clean it? |
I can't see it |
Only things to watch mixing motors with water are:
1) Bronze bearings are designed/made to act like a sponge to hold oil. If you wash the oil out & fill the "sponge" with water, you won't fit any more oil in. So, it's a good idea to saturate the bearings with oil before getting water in there, & try to avoid strong detergents or solvents that could wash the oil out. It's possible to re-saturate dry bearings by heating them up in an oil bath, but this might be awkward if they're permanently fitted to something like a motor. 2) Brush wear is relatively fast when running under water, probably due to arcing & the continual washing-away of the lubricative graphite/carbon (The accelerated wear is the main reason you run-in a motor under water, to get the brushes to fully contact the comm, ie for maximum current transfer & timing correction, as quickly as possible). I personally clean motors out by dismantling (Where possible) & washing out in diesel, avoiding the bearings (Not a major issue if they get damp with it as diesel is a light oil anyway). Then a blow-out with compressed air & re-assemble. Don't use strong solvents (Petrol, thinners, acetone etc) as it can attack/dissolve the enamelling on the windings of cheaper motors (I'll lay money Annsmann fall into that category!), not to mention, have the oil out of the bearings
