Re: hopping up a vintage grasshopper 14 years 9 months ago #6141
that would be cool, they should fit ok then :woohoo:
2 wheels done now and carbon fibre shell. i think it looks better than the white
Re: hopping up a vintage grasshopper 14 years 9 months ago #6142
That looks awesome dude. B)
Great choice to do the wheels in black. Very slick with the carbon combo.
Re: hopping up a vintage grasshopper 14 years 9 months ago #6143
And Louisbaby's parts got delivered today! :cheer:
He sent a big bunch. So much that I'll have to sorten it out a bit.
But I've alraedy seen oil seals, springs and more shocks for you! :woohoo:
Re: hopping up a vintage grasshopper 14 years 9 months ago #6144
oh my god, i cant thank you both enough :cry:
the carbon fibre is awesome.
Re: hopping up a vintage grasshopper 14 years 9 months ago #6156
That does look super awesome dude.
Re: hopping up a vintage grasshopper 14 years 9 months ago #6167
i am having a SHOCKING time :cry:
managed to get the rear shocks to fit, i bought some mini ball joints for the bottom which helped. they are not bolted up tight yet as i still need the oojameflips for the bottom of the springs to sit on.
trouble is now, neither the hopper or the hornet body will fit on without gouging loads of plastic out of them. :cry: which i dont really want to do.
plus there seems to be a lot of strain on the top mounts because of the angle which would surely result in premature breaking with heavy off road use.
i am stuck now as to what to do, any ideas anyone apart from stick with the original shocks?
Re: hopping up a vintage grasshopper 14 years 9 months ago #6168
Could you show some more details?
Like what you used on the top of the shock and maybe a picture of where the body lacks room to fit...
Re: hopping up a vintage grasshopper 14 years 9 months ago #6169
i am using the hornet shock extension mounts on the top
i think i may have found a solution :woohoo:
the shocks will fit on the inside of the adaptors at the bottom, which lines them up better, and if i remove the hornet top mounts and bolt the top of the shocks on the normal hopper mounts it should be ok......watch this space.......
Re: hopping up a vintage grasshopper 14 years 9 months ago #6170
looks better, shocks are more of a decent angle but now the left shock (looking from the rear) is hitting the gearbox. i give up. i guess i will have to stay with the standard shocks on the rear :cry:
Re: hopping up a vintage grasshopper 14 years 9 months ago #6172
I'm thinking of a 'normal' mounting at the lower end and a small bracket at the top to lower the shocks a bit (for the body) and with which you can also create some extra offset so the shocks line up better...
