I'll have a look in the manual if the Hummer thingies are suitable for a ball end...
Do you think that might solve the issue? Edit - they are also attached with a 3x14mm step screw... |
First thing I can come up with is put a ball end in the mount and use a matching ball connector on the bottom of the shock. But that'll give a new issue with the disc(thingies) that go on top of the connector.
I think we need a bit of a tech brainsorm and possibly a small search here... I guess I hadn't been thinking enough... But I have to say it sounds like a common modding problem. |
That might put a drain on the budget. Those metal caps only work well if you have the original Hornet oil shocks...
Don't think the lower ends can be found seperately. But it shouldn't take too much to find a solution! |
maybe a couple of these would solve the situation?
www.ebay.co.uk/...2121wt_821 |
I think you can attach the lower end of the shock with a normal 3mm tapping screw then...
Which ones do you mean exactly? Those from the Hummer? |
