oops, forgot you said no mail on mondays.
what springs do i need for the shocks? i have some lunchbox springs which fit over the shock body but there is nothing to support them at the bottom. i could make up a spacer to fit or can you buy these parts seperately? |
The Rims need black!
no worries about the D1 parts, i can wait for the shocks, they will go on the hopper. the thingemywotsits look the same to me i think black rims would look good too, make it kind of a stealth car, the white sides are going too, going to be carbon fibre. do you think the lunchbox springs will work ok? i still need to get some front shocks for the hornet so im not in a rush |
Don't have any Manta Ray D1s anymore - just checked...
I could mail you some from a Hummer CVA - with the little whateveryounameits. They're a different combo. But I'll have to see if the springs have the same diameter. I'll double check on the Lunchbox springs but if they fit on the damper housing, I see no reason for them not to be a match. Btw - cool idea with the carbon. |
I came across your '
original grasshopper rebuild
' topic yesterday.
Seems to me it's part of this Hopper quest so I think I'll change the title to this one and merge the two... |
ok, your the boss!
on the dampers, there i the body (obviously), the caps either end, the steel rod in the middle and the ball joint oojameflips at the bottom. there are also 4 o rings, 2 for each damper i guess and a little black plastic spacer. what order do these bits go together? |
