Mmm... I can't seem to locate separate spare oil seals for this one.
Not sure what would be a good replacement. I think that is quite hard - 4000. I'd look in the direction of 1000 or so. I use even softer, about 600-800. Not a damper oil specialist myself though... 100 is the thickness of water btw. If I'm correct. And 700 (for example) is seven times thicker than water. |
I wouldn't go too thin on the oil. Lars recommended thicker oil for older shocks in one of his builds.
Had a look on their site and I'd go for this one : The oil seals also function as a bit of pressure damper so they have another purpose. But you might get away with the wrap idea... |
my darling wife has just bought me these as an early birthday pressie, thought it was a too good a deal to turn down
www.ebay.co.uk/...1423.l2649 just hope i can get them to fit! |
oooooooooooooooohhhhhhhhhhhh BADWORD!!!!!!!!!!!!! i had just made my mind up on satin black wheels, the carbon side walls and now you have completely destroyed my only brain cell and got me rethinking all over again ! |
wheels are going satin black. 1 sprayed just to make sure i am happy with it.
having trouble with the new rear shocks got the hornet top mounts on and i got some bottom mounts (dont know where from?) that fit over the gearbox. seems like there is a ball joint affair going on here. i have the mounts and the ball joints but it looks like i need some little covers to secure them on. anyone got a couple spare or if not what are the part numbers for them? Edou, will the ball joint thingies screw on to the bottom of the shocks you sent me or do i have to work out a different solution? |
yeah i got them but the shocks fit on a funny angle, dont look right to me |
