Re: hopping up a vintage grasshopper 14 years 9 months ago #6204
The U-bracket for the top is in the elaborate screw bag A from the Rising Fighter so that's not very interesting :
But I think you'll also be needing some of the screws...
Re: hopping up a vintage grasshopper 14 years 9 months ago #6205
BA15, BA17, BA20 and BA21 are unavoidable parts. Never underestimate a modification. :S
I hadn't gotten to the proper tie rods on my own Grasshopper...
The other items needed (screws) are quite generic.
Re: hopping up a vintage grasshopper 14 years 9 months ago #6206
why would i need BA21, thats a steering arm ?
Re: hopping up a vintage grasshopper 14 years 9 months ago #6207
Yeah, the longer suspension arms also require longer steering arms...
But I think the U-bracket from the GH suspension arms can be recycled to fit the top. :cheer:
So it's just the rods and the screw pin you need in addition.
Have to double check if I'm not missing anything...
Re: hopping up a vintage grasshopper 14 years 9 months ago #6208
can you post me a new brain cell while you are at it, mine is getting a bit knackered :cry:
Re: hopping up a vintage grasshopper 14 years 9 months ago #6209
So it the rods and the screw pin you need.
hang on a minute, that pic shows the standard hopper suspension arm, with the u bracket :silly:
Re: hopping up a vintage grasshopper 14 years 9 months ago #6210
Yes and you don't need them on the Rising Fighter arms. :cheer:
Re: hopping up a vintage grasshopper 14 years 9 months ago #6211
I've sorted out what Louisbaby sent me. Of use for you I think will be a set of (complete) yellow CVAs, extra oil seals for the shocks I mailed earlier and a bunch of different springs.
The shocks have a vintage lower connection. This is one piece so you don't need the discs that go on top.
I'll also send you a couple of silver damper housings. Don't know what you could do with them exactly but they look cool.
What's missing (in total) though is a matching set of lower connection discs for the CVAs you already have.
To go on top of the special metal connectors you got earlier and to support the spring...
I only have 1 small and 1 larger one.
Don't really like to break up the Hummer sprue for them. I'd be left with a non-matching other half... :S
There are some (partially incomplete) Blackfoot shocks (I think) but they will be too long for your purpose.
And a pair of Frog dampers which will be too short. And I kind of like 'em... :whistle:
So all that's missing for two complete pairs of oil filled dampers would be one matching discmountiewhatsemethingy.
Re: hopping up a vintage grasshopper 14 years 9 months ago #6212
haha what ever i get will be a bonus and im sure i can cobble something together out of th e thingamyoojywhatits you have added. thankyou
Re: hopping up a vintage grasshopper 14 years 9 months ago #6213
Are you going to order the Rising Fighter arms?
I added a UK seller that had them for 3 pounds a little earlier in the thread...
Located the separate 3x22mm screw pins on eBay also btw.
With a little more modding - and some 2 or 3mm rod end - you could even create some steering arms yourself. :huh:
And eliminate the slack that's in the normal steering setup.
Time to create page: 0.159 seconds
