it comes with little rings, different thickness to add or reduce spring tension.also has 2 different size bottom ball joint mounts to alter the actual height of the shocks. i will have to wait until it is all bolted up properly before i can determine what adjustments are required |
No easy bracket fix?
Thinking about designing a larger one that will attach to both sides for stability. Maybe monster_beetle could fabricate them. But that'll take a little while... Remember you did a nice job on modding the Hopper body earlier. |
the original bottom U brackets dont really fit on the top upside down very well but i suppose with a bit of modding they would work as a temporary fit.
i was thinking of a "brace" between the 2 top mounts myself. as you say would add strength and stability, and if made well would look really cool |
maybe something similar and as simple as this, if the ends were bent to the right angle to fit the top suspension mounts and maybe curved in the middle or even bent to mimic the hoppers body profile?
www.ebay.co.uk/...2c5eeec37f |
The right length, a second couple of holes to connect the towers and a slight angle at the end would do the trick.
I bet that'll look very slick already... Don't see an easy way to avoid using brackets to mount the shocks. |
