toying with the idea of getting some of these.,,,
www.ebay.co.uk/...2131wt_824 dont actually do anything but they would look cool......i think |
me too! looking at them again i cant see how they would fit with hex adaptors. i think they are meant for 4 wd cars with hex wheels on standard axles. but he says a 4mm hole and an 11mm pin. im confused now
i think i will forget these unless anyone has any better info on how they fit? |
I think that the Hopper qualifies when it comes to those specs...
Still I have a bit of doubt if it will fit straight on. But more in regard to the length of the axle. Edit - Sounds like they would replace the normal hexes so I think that won't work on the rear with the Frog adapters. On the front you'd have to shorten the brass hexes also... |
I had a set of those, you remove the hex adapter, and push that on in it's place. It basically is a hex adapter with a disc on it. They looked killer on my drift car, and on my crawler...
My Projects:
Sorry dude, got rid of my drift machine years ago. They are a standard width, I think 6mm or 8mm.
My Projects:
No mail on Mondays anymore in this country.
Hoping tomorrow... The bits I sent had a fast trip though! I'll mail you the other parts as soon as I can.
The following user(s) Liked this: agemax
