That'll keep it from hoppin' around a bit. You've probably still saved on the total weight with the new gearbox axle. Should be interesting to see how much exactly the difference will be... Btw - sounds like a solid plan with three bearings. |
My Projects:
Last edit: by Louisbaby.
Outside face of the pinion should be 16mm from the face of the motor according to the re-re insctructions
The following user(s) Liked this: agemax
ok everybody,i have got myself into a complete mess over this the 7mm hex spacers were made for the standard hopper stub axles,my hopper has the lunchbox stub axles and use 16mm hex spacers so i am going to get them machined to fit a bearing in each end which i am sure will be more than enough to take the load. sorry about the confusion |
M3 x 3mm
dont worry Edou, thankyou anyway. i have to go to the nut and bolt shop anyway to get some other bits and pieces, i am sure they will have them,probably about 2 pence each
Last edit: by agemax.
